12-29-2016 06:52
12-29-2016 06:52
Dear Person With Answers,
I have had the Surge for over a year now and just this month it stopped syncing, Dec 22nd to be exact. I have tried all troubleshooting ideas, with no luck. At this point it just is a watch to tell the time.
-I have uninstalled and reinstalled the FitBit App a couple of times.
-I have restarted the device several times, and shutdown the device.
-I have tried to figure it out from the dashboard on my desktop.
-I have checked the BT connection, it sees it but says that the "Pairing rejected by Surge"
-When trying to sync from App, says "Tracker not found"
Please help!
Sincerely,
Beyond Frustrated
12-29-2016 07:19
12-29-2016 07:19
No ideas yet but, curious, what device are you connecting to?
Best Answer12-29-2016 07:48
12-29-2016 07:48
I have the same problem described by Coconumberfive. The trucker is Surge and the phone is Lumia 950XL. I use them since May 2016. Since December 23 are no longer synchronized. I tried all sorts of tricks. Without success.
Best Answer12-29-2016 08:10
12-29-2016 08:10
Best Answer12-29-2016 10:18 - edited 12-29-2016 10:19
No guarantees, but try this workflow and see if it helps (I know you've probably tried a combination of these already).
Best of luck!!
11-16-2019 19:48
11-16-2019 19:48
Following the steps exactly connected it.
