Hi guys,
I recently purchased a Surge. Great device, and i'm very happy with it, however I am finding it very hard to get any information about portable charging options.
While fitbit do not recommend anythings other than charging on a USB via laptop/computer, this offers no flexiblity for someone who may need to charge, and not have access to a computer!
I'm going to be doing a multiday hike, and I would like to try record my days.
My battery will not last 6-7 days with GPS, and carrying a laptop etc is out of the question!
Is anyone charing the Surge with a battery pack, and if so can you recommend one that will work?
Many thanks,
J
Hello @jusmeig,
Welcome to the community!
I charge my One with a battery pack occasionally and it works; in fact, I just did it a couple of days ago. The potential problem with charging from a battery pack is that it may charge too quickly and damage your device or overcharge it.
I imagine you'll be perfectly fine if you charge up to about 75%, a little each day, and disconnect it. The one I have is a Tylt plug in model.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Best AnswerThanks for the quick reply.
I'm guessing something like this might do the trick?!
I paranoid I will plug it in and fry it!
