05-31-2017
20:11
05:11
YojanaFitbit
05-31-2017
20:11
05:11
YojanaFitbit
Can I power wash wearing my surge? My arms get wet (equivalent to standing in the pouring rain for about an hour).
05-31-2017 20:24
05-31-2017 20:24
Gets wet it will more an likely die. But its up to you if you want to ruin the warranty
Best of luck to you!
Wendy | CA | Moto G6 Android
06-02-2017 05:10
06-02-2017 05:10
Hi @WendyB, nice to see you here! I've noticed you are new around @Matgrover, so let me give you a warm welcome to our Community.
Fitbit Surge is water resistance but it means that it can take splash and sweat, in this case I'd consider taking it off to avoid future issues. Although if by any chance you forget to take it off and it gets wet, take in count the Wear and Care tips to clean and dry your band.
Good luck and keep enjoying your Surge!
