05-09-2020 09:14
05-09-2020 09:14
Need to reset the watch . . . how? The time is off . . .
Best Answer05-10-2020 00:09
05-10-2020 00:09
You can't manually set the time, but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
05-10-2020 09:54
05-10-2020 09:54
Hi. Could you let me know where you managed to get a strap for your Surge.
05-26-2020 08:47
05-26-2020 08:47
@Kaizad_Driver look on Amazon, YouTube also has videos on the process to change bands.
Best Answer05-26-2020 09:28
05-26-2020 09:28
