01-03-2016 13:38
01-03-2016 13:38
Good aftenroon,
Looking for advice/best practices on charging my surge while travelling.
The manual, of course, recommends charging via USB port on computer, but that's not an option while travelling.
It also says I can use any USB wall charger, which is fine except when camping.
I noticed the help file here on the website says I can also use my car's USB port for charging the Surge. Haven't tried that, but I will.
So, for camping - how safe is it to charge my Surge with a Zagg or iFrogz style battery pack?
Best Answer01-03-2016 14:53
01-03-2016 14:53
not sure they have any yet, see previous post here:
https://community.fitbit.com/t5/Surge/Battery-Pack/td-p/752339
Best Answer01-04-2016 00:52 - edited 01-04-2016 00:53
according iFixit reference, the Surge is well protected againt bad USB charger
https://fr.ifixit.com/Teardown/FitBit+Surge+Teardown/42344
http://www.ti.com/product/bq24232h/description
the battery is a lssp491524ae 3.7V 100mAh
https://www.google.fr/search?q=lssp491524ae
any battery pack must work, i will try one, probably in january
