07-17-2016 23:33
07-17-2016 23:33
00:08
12:44
07-18-2016
00:08
12:44
Hi, @Lukepenry, I would suggest putting it in a bag or bowl of rice, making sure the Surge is completely covered. Leave it there for 4 or 5 days. The rice should absorb the moisture. Once it has had 4 or 5 days check to see if the screen looks dry. If not, refresh the rice and try a few more days. If it looks dry after 4 or 5 days, give it a good charge and then a restart . Hopefully that will sort everything out. If not, then you will need to contact Customer Support and let them know what happened. Contact.fitbit.com .
Good luck, and keep us posted. Welcome to the forums!
07-18-2016 23:36
07-18-2016 23:36
Best Answer07-19-2016 05:37
07-19-2016 05:37
08-18-2016
04:51
12:44
08-18-2016
04:51
12:44
@Julia_G I noticed that my friend @Julia_G advised just great and I would like to follow up on this. Were you able to contact our Customer Support team? If so, I'd like to know what was the outcome in case you need further assistance.
Looking forward to your response my friend! ![]()
