Best AnswerWith the Surge laving the GPS on while inside a building, cause excess battery drain.
To leave the GPS on the Blaze and Surge will need to be left in an actively talking mode, such as walking
ya the gps should be shut off and on only when it is needed or else it could easily the drain the battery off
@45marathonsaaa wrote:
Thanks for the information. I have a Surge and I have to charge ever day when I'm going 14,000 to 30.000 steps a day. It runs the battery so much I have to charge the l have to charge my Surge sometimes two times a day.
Hmmm, I often log 30,000+ steps in a day, and occasionally that many on a single GPS tracked run, and my Surge's battery only requires charging every second or third day. Have you power-cycled your Surge; earlier this year mine got into some sort of a power burn mode and I was needing to charge it at least once per day until I restarted it.
Best AnswerI've also disabled the "All-Day" update feature on my phone; that seems to help a bit as well.
