Reaction to SURGE band
I have only had my Surge for most of this month and several times I have had to remove it due to a reaction on both sides of my wrist. It is red, itchy and drives me crazy!!! I was reading up on how to clean my band and it mentioned rubbing alcohol. I am guessing I can is Isocol?! Just looking for users who have successful used rubbing alcohol and their rash has not returned. Does this method really work?
1 REPLY 1
Yes Isocol is used for cleaning the surge, you could also try using a barrier cream (nappy rash) on your arm where the surge sits after cleaning. I originally had a surge and after a few weeks I started getting a red sore area, someone else on the forum suggested this which I tried and it did work. Unfortunately I had issues with the surge and purchased a competitors fitness tracker and haven't looked back.
