12-21-2017 12:33
12-21-2017 12:33
I need to replace my Surge but can’t find on website. What should I replace it with?
Best Answer12-21-2017 20:01 - edited 12-21-2017 20:02
First off I would contact support as they should give you a discount.
Tell them whats wrong with your surge and any trouble shooting you did with it.
The go to the compare page and decide from there
https://www.fitbit.com/compare
I myself would go for the Ionic its closer to the surge than the blaze. Blaze used Connected GPS and its iffy IMHO
FYI Surge has been discontinued
Wendy | CA | Moto G6 Android
Best Answer12-21-2017 22:07
12-21-2017 22:07
