02-08-2017 00:32
02-08-2017 00:32
I received a new surge today after the strap wore out on my old one. i did not get a new dongul will new surge work with old dongul
Best Answer02-08-2017 00:37
02-08-2017 00:37
Yes, the dongle works with any fitbit.
02-08-2017 00:37
Best Answer02-08-2017 00:56
02-08-2017 00:56
Best Answer02-08-2017 01:00
02-08-2017 01:00
You'll need to add the replacement Surge as a new device (double click the fitbit connect icon at the bottom right of your screen). It should ask if you want to replace the old one.
Best Answer02-08-2017 01:49
02-08-2017 01:49
thank you Steve all up an going.
