04-25-2016 20:43
04-25-2016 20:43
04-26-2016 00:42
04-26-2016 00:42
The 8 steps could just be from jiggling the watch during setup.
The calories will be down to your BMR calories. These are the calories you burn just keeping your body alive (even when asleep). They are calculated from your profile settings so you don't need to be wearing your fitbit to get them. What you are seeing is the total BMR calories since midnight.
04-26-2016 03:50
04-26-2016 03:50
Your calorie burn is correct; no need to be upset with your Fitbit.
04-26-2016 09:21
04-26-2016 09:21
04-26-2016 09:28
04-26-2016 09:28
Your fitbit tracks 2 kinds of calorie burn. Those burned through activity and those you burn just by being alive. It's this second type that it can calculate just from your profile, without being worn, and without being telekinetic.
04-26-2016 09:46
04-26-2016 09:46
04-26-2016 09:58
04-26-2016 09:58
@SunsetRunner wrote:
Sorry, I didn't know that the surge had telekinetic capabilities... I thought I made it clear that the watch came straight from Fitbit, I had just charged it and it had NEVER BEEN WORN... Therefore, it is impossible for it to calculate my heart rate and calories burned. The fitbit should be calculating calories burned by using a formula using the data received... age, height, weight, steps taken, heart rate, etc. The heart rate is a very important key factor in accuracy. If your fitbit is still counting calories and a heart rate while it's sitting on a table, there is a problem...
Once again you've missed the point; as you already had a profile built which provides some basic metrics, as soon as midnight rolled around it assumes you haven't died and are therefore burning calories staying alive. Think about it this way; turn your Surge off at say 11:59 PM, and then restart it at say 11:59 the next day; it will show your basic subsistence calorie burn, but nothing else of your activities.
