I've noticed you are new around @JulianH, so let me give you a warm welcome to our Community. ![]()
That's odd, does it happen when the Fitbit Account is syncing via Bluetooth or specifically when you're navigating through the App? You can try to force quite the Fitbit App to see if this helps.
Have a good one!
Thanks for getting back @JulianH! Please check if your iPad and Fitbit App are up to date. And as mentioned before, reboot the App whenever you get this issues. Do you know what model of iPad are you using? ![]()
I'll be waiting your response.
Thanks for confirming that information! That's really odd, I've just checked the list of supported devices here and if you're using the Apple iPad Mini 2nd gen, it should be compatible. But thanks a million for the feedback, I'll make sure to pass it along to take it in count for future updates.
Thanks for your patience!
Thanks for your reply @JulianH and for checking those details! If it is not that iPad, would you mind just confirm if the one that you're using is listed here. I appreciate your help with this.
I'll be around.
Thanks for checking that information @JulianH. Now we know exactly why it is not connecting. If you want to upgrade remember that you can use other devices to sync too. I hope you can find the best option for you.
I'll be around in case that you need anything else.
Best AnswerI have now upgraded my iPad to latest version but still have the screen rotation problem!
