03-19-2017
07:04
05:25
YojanaFitbit
03-19-2017
07:04
05:25
YojanaFitbit
When I press the select button to start stopwatch nothing happens. Have gone to elliptical, pressed the tick in the bottom right hand corner but when I press the select button, stopwatch won't start. Seems to be the same on other workouts too.
Moderator edit: Clarified subject.
03-20-2017 05:23 - edited 03-20-2017 05:24
A warm welcome to our Fitbit Community family @Tunafish! That's odd! Have you tried to restart your Surge, it might be that it is just stuck. Is the screen working? You can pick the "Elliptical" workout on the screen too, then you can tap on the check mark on the corner to start the activity too.
Hope this helps!
Hope this helps!
