I am wondering if they will be updating this app for the Surge to show better detail? My dashboard says I was restless 37x and awake 4x and there was 9+ hrs of sleep but I feel like I didn't get any useful sleep or not enough. This is one of the reasons I bought this product was to help my sleeping issues and the fact that I have trouble getting good sleep
Best AnswerHi, @ncoffer, if you feel that the Surge is over estimating your sleep then you may find that the "sensitive" setting is more appropriate for you (though 37 times restless already sounds like a lot!). On sensitive even small movements will be registered.
If you would like to experiment with your sleep setting to see which works best for you, you can find this on your app. Choose Account and then scroll down to Settings. Choose Advanced Settings and on that screen you will find Sleep sensitivity.
Be sure to sync your Surge when you have made any changes in your app.
You might also want to have a look at the forum area under Sleep Better for more tips, information and discussion.
I hope this helps. Welcome to the Community!
