Sleep delay about 2 hours
Starting to track sleep and it has consistently been delayed by about 2 hours. For example last night I went to bed by 8:30 pm exhausted and was definitely sleeping by 9pm. In the morning the wake my sleep cycle doesn't begin intil 1030. This is a consistent issue.
1 REPLY 1
I hope you're doing great @Mfogg! It's great to hear that you're taking advantage of the automatic sleep mode, maybe because of the movement while you're sleeping your Surge detected your sleep later, you can edit it on your sleep log in order to have it as accurate as possible. I recommend you doing the restart this will refresh the internal logs from your Surge and will help to keep it accurate.
Hope it helps, let me know how it goes!
Magin | Community Moderator, Fitbit
If you find something helpful, give it a vote and don't forget to mark it as an Accepted Solution!
