01-06-2016 04:07
01-06-2016 04:07
Best Answer01-07-2016 16:53
01-07-2016 16:53
Congratulations for your baby @Mamarunner!
Is nice to see you around and actually, yes you can change the sleep tracking to "Normal" and also you can log manually your sleep by following the instructions in this article: How do I manage my sleep logs with the Fitbit app?
Let me know if you have any additional question, I'll be around for you! ![]()
If this post was helpful vote for it or accept it as a solution! Remember challenge yourself and become better than yourself. Share your story!
Best Answer01-07-2016 17:44
01-07-2016 17:44
01-08-2016 10:13
01-08-2016 10:13
Thank you for clarifying the issue @Mamarunner!
In that way, yes, you need to change the "Sleep Tracking" to "Normal", because, "Sensitive" was design for people with irregular sleep, so they can make more moves and the tracker is not going to count those moves like awake time. I found this article for you about Sleep tracking FAQs, where you can find a lot of information to improve your Zzzz. ![]()
Let me know how it goes!
01-09-2016 09:05
01-09-2016 09:05
Best Answer01-10-2016 02:42
01-10-2016 02:42
I found that when I had my sleep setting on normal and was getting up every couple of hours to settle our newborn, the FitBit wouldnt recognise the movement and log it as sleep. I changed it to sensitive setting and it seems to reflect my nights more accurately - perhaps a little oversensitive at times, but it gives greater insight. That's my personal preference anyway!
01-11-2016 10:14
01-11-2016 10:14
Thank you for sharing this information @PJB84M, is nice to have you here! ![]()
@Mamarunner, the reason why you are seeing your sleep pattern in that way, is because, your tracker is recognizing every time you are awake. But, don't worry, if you want to have the sleep pattern complete, you should manually log your sleep, by doing the following on this article: How do I manage my sleep logs with the Fitbit app?
Keep me posted!
