05-01-2016 16:37
05-01-2016 16:37
05-02-2016 10:38
05-02-2016 10:38
It's nice to see you around @Andras1, hope you're doing great today! By any chance, are you syncing frequently? Are you using MobileRun or any other app to track your data? Only Fitbit Surge includes built-in GPS. Fitbit Blaze can provide GPS data but only in conjunction with the sensors on your nearby mobile device. For both trackers, turning on multisport mode gives you the option to select a GPS exercise.
If you wear your tracker while using MobileRun, the steps, active minutes, and calories burned that you see on your Fitbit dashboard come from the tracker. Otherwise your phone is used to calculate this data. During the workout you can view your elapsed distance, time, and average pace as well as use the music controls in the Fitbit app.
Also, have you manually logged any activities? Typically, your steps will be recalculated if you manually log an activity as the manually logged activity takes precedence over the steps you tracked while wearing your tracker at that point in time. For example, if I am wearing my Surge and walking and I reach 10,000 steps, then I go to the computer and manually log an activity that starts and ends at that point in time for say 1 hour, Fitbit will calculate how many steps you took and it may bring my step count to something below 10,000 steps. To clarify, activities should only be manually logged when you forget to wear your Surge. Hope this helps!
05-02-2016 14:04
05-02-2016 14:04
05-03-2016 06:45
05-03-2016 06:45
Music to my ears @Andras1 , I'm very glad to hear that you're back in business!
Amazing job what you've done so far, 14 kilos off? Wow, I've lost just 2 hahaha . You're missing 6 kilos which I know is nothing for you now, I'm pretty sure you'll loose more than that.
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community, so you can go ahead and log to any of the topics that might be of your interest in our Discussion boards, but what about taking a look at our Weight Loss board?. Feel free to comment and contribute with your knowledge and experience.
Happy stepping my hero!
