02-12-2018 05:53
02-12-2018 05:53
Step counting when moving my arms?
Changed my Fitbit to the other wrist and set it up and it still counting them when I move my arms! As I was adviced to do this before and still hasn’t made a differences.
I bought a cheap version of a Fitbit and it never done that, only counted my steps when I actually walked or done was at the gym.
The calories on a Fitbit are way off. Very disappoitnted and thinking I will be going back to the cheaper version. Works far better!
Maria!
Best Answer02-13-2018 10:55
02-13-2018 10:55
All wrist models will count steps when the arms are moving.
you can try changing the Wrist to be the opposite that you wear it.
That does help some
Under settings and Wrist. Mine is set to Non-Dominate when I wear it on my Dominate wrist
Wendy | CA | Moto G6 Android
Best Answer02-13-2018 11:36
02-13-2018 11:36
