Surge 2 minutes behind my iPhone time
ANSWERED
How can I get  the time on my Surge to be the same on my iPhone? Can I manually change the time on my Surge?
Moderator edit: Updated subject for clarity.
1 BEST ANSWER
Accepted Solutions
Nice to see that you're digging into the Forums @904GMS, let me give you a warm Welcome to our Community. Smiley Happy
That's odd, it usually takes your phone's time after syncing. Why don't you check the steps here, to see if after doing this the time on your Fitbit changes..
Hope this helps.
3 REPLIES 3
Hope this helps.
When I put surge on charge the time is wrong how do I reset the time on my surge
Hi @Supergran2403, thanks for joining this family, hope you like what find here! Smiley Very Happy
I think that you need to restart your Fitbit and sync your it using these instructions:
  1. From the Fitbit app dashboard, tap the Account icon.
  2. Tap your device tile.
  3. Tap Sync Now.
If it is not working try the steps in this post. You can try that while it is connected if you wish.
See you around.
