@TeffNeff Welcome to the Fitbit Community! Thanks for your feedback! For Australia the warranty lasts 2 years I believe. Have you received a response from customer support already? I'm sure they will find a solution for you right away.
Let me know how it goes! ![]()
Best AnswerI have gone through 2 bands in 18 months. I will now be ordering one of these to see if they last longer; https://www.aliexpress.com/item/Silicone-Replacement-Watch-Wrist-Strap-Band-For-Fitbit-Surge-watch-b...
Welcome to the Fitbit Community @Zane @Gizzo0604!
@Zane I recommend contacting the Support Team so they can review the warranty of your tracker.
@Gizzo0604 Since this is not a Fitbit accessory we can not guarantee that's going to work I suggest you to contact Support so they can see your options.
Best AnswerThank you MaginFitbit! I did so, but no luck!
My first surge needed to be replaced before the warranty expired, and was replaced with 2-3 refurbished surges, none of which worked. I was then sent a new surge (Thank you, Fitbit!) which did work properly. This replacement surge bubbled and peeled at 6 months, but since the warranty didnot re-start, I was told that the 6 month old replacement is off warranty. I understand the policy, but that policy makes it harder for me ot be loyal to Fitbit, a product I have loved using. I am not rough with the watch at all... I am 56 yrs old and treat it with respect. I have superglued the edges for now as the watch works, but it is not a bit rough and unsightly!
Thanks for following up! I am still stepping away!
