08-11-2016 16:26
08-11-2016 16:26
Hi, I have a 390 day old Surge with a screen that blanks out and is completely unresponsive. They only way I can get it back is to put it on the charger. It immediatloy boots up and has 50% battery life as soon as I plug it in. I have tried the normal restaring to no effect. Is there a way to recalibate the battery? I no longer get low battery warnings either. Support has offered a 25% discount, but frankly I am not too keen to spend another 200.00 over and above the 250.00 I have already spent on a product that isn't going to last more than a year. So if I can get it back to good I would rather do that.
Best Answer08-12-2016 07:08
08-12-2016 07:08
Wonderful troubleshooting @Strandedvandal
It's not possible to recalibrate the battery. Aside cleaning the tracker & restarting there's nothing else to try ourself in attempt to fix..
If not already done, check out the Fitbit Help Article:
URL: Click to go to the Fitbit Help Article 'My tracker's battery isn't charging'
How to clean the tracker? YouTube Video (By Craig) (For flex but similiar for other trackers)
http://www.youtube.com/watch?v=ezvXy9mKoGQ
Hope it helps
Best Answer08-15-2016 06:10
08-15-2016 06:10
@Strandedvandal Welcome to our Community! One more thing I would like to comment is that you charge your tracker for 2 hours even though you see it showin half the charge when you plug it into your computer. This may help improve it's battery life and also try @SunsetRunner's great suggestions.
Let me know how it goes!
