10-23-2017 03:55
10-23-2017 03:55
Hi,
I've had a Fitbit Surge for about 14 months now. In the last 6 months I have had an issue with the buttons not working straight away. They will not respond and I have to keep them depressed for 10 seconds, press 2 buttons at a time and I need to keep doing this for up to a minute or sometimes longer. I am in a running group and I have to hold up my group until I can get the surge into the run mode. It is frustrating when this happens especially when they have their watches ready at the first press of their button. Does the surge have a life of 1 year or less or have I bought a lemon. Curious to see if others have a similar issue that they they may be able to assist with. By less than 1 year I mean that I started having this issue at about 8 months after I bought this. Any advise or suggestions??
10-23-2017 11:03
10-23-2017 11:03
You should of contacted fitbit when the problems began. It would of been replaced. But now its out of warranty.
https://www.fitbit.com/legal/returns-and-warranty
I know of no way to fix the problem Sorry
Wendy | CA | Moto G6 Android
10-23-2017 12:06
10-23-2017 12:06
@stevekak If you live in Europe your warranty period is for 2 years (so you may still have a shot). If you live in the US then you are out of luck.
10-27-2017 13:27
10-27-2017 13:27
Thanks for your response. You're right I should have gone back to the store straight away, Lesson learnt.
