01-30-2017 11:35
01-30-2017 11:35
Anyone have intel on which is more accurate? I have a new Keiser M3i spin bike that seems to have good tech. The Calorie burn from it is indicating higher (approx. 20-25%) than my surge. I'm thinking the bike would know exactly how much energy it would take for the given resistance and distance whereas Surge algorithm may be a SWAG. Thoughts?
01-30-2017 12:08
01-30-2017 12:08
Hi, @Swishhh, my thoughts are that if you feel you are getting an accurate HR reading from your Surge it will be the more accurate.
Heart rate elevation is a good indication of calories burned over BMR (basal metabolic rate). In this case your Fitbit probably knows better than your bike, because it knows about YOU.
01-30-2017 13:51
01-30-2017 13:51
@Swishhh the science for cycling shows that power data is most accurate estimate of calorie burn. Your Keiser bike calculates the total power/energy you generated while riding, so it will be more accurate than your Surge.
Here is one article that discusses the differences:
http://home.trainingpeaks.com/blog/article/how-accurate-is-that-calorie-reading
01-31-2017 06:31
01-31-2017 06:31
01-31-2017 06:32
01-31-2017 06:32
