01-01-2016 15:50
01-01-2016 15:50
Hi Fitbit community,
I've noticed a bit of a dissapointing issue with my fitbit surge and the functionality of using bluetooth headphones in conjunction. From what I've seen searching around the forums, people are having similar issues, but some are able to use their bluetooth headphones with the bluetooth surge (classic) without any interference or compatibility issues.
Here's a quick rundown of what's causing me issues:
Samsung Galaxy S5 paired with Surge (Classic) works fine. Powerbeats2 Wireless Headphones works fine with my phone. However the issue comes when I try to use the Surge (Classic) with the Powerbeats2.
More complicated Rundown:
Upon using the headphones connected to my phone, all I have to do to pair is press a button on top of the headphones to connect (which is super convenient) given that my phone's bluetooth is turned on. Now, if I have Surge (Classic) connected before I connect the headphones, it may allow me to access the song track via my Fitbit Surge for one song before it kicks me out of my tracklist on the watch and says "No Music" on the screen if I'm lucky, or it may kick me out and not connect at all. On the reverse side of this, if I connect my headphones first, then double tap my surge to pull up the music track it will say "Connecting..." and fail to connect. Also, another interesting thing to note is that in the bluetooth settings on my phone, under paired devices it says:
Powerbeats Wireless
Connected to phone and media audio.
Surge (Classic)
Connected to input device.
---- It seems as if everything is in order here and working properly, however the functionality just doesn't work.
If anyone smarter than me would like to enlighten me on the issue I would appreciate it very much.
Thanks
Best Answer01-04-2016 15:43
01-07-2016 14:03
01-07-2016 14:03
getting tired of bumping.
Best Answer01-08-2016 15:40
01-08-2016 15:40
Anyone?
Best Answer01-09-2016 08:03 - edited 01-09-2016 08:14
So let me understand, and correct me if I'm off track:
Your trying to connect your BT earbuds and control the music with the Surge?
Edit:
FWIW - Mine works with my BT headphones without an issue. I had to manually connect the Surge after the headphones were connected - it didn't just connect on it's own - then just double-press the home button, and the screen showed the song that was playing and was able to go to the next song. Worked with both the stock music app, and google music.
Granted, I am not using the same earbuds, so that could be the issue...
Best Answer01-09-2016 13:03
01-09-2016 13:03
Yes this is exactly the problem. I believe there must be a compatibility issue? But not sure..
Best Answer01-11-2016 14:39
01-11-2016 14:39
Still no answer here, someone please help me fix this it's bugging me. #FirstWorldProblems
Best Answer01-11-2016 23:15 - edited 01-18-2016 22:04
The problem comes from the priority of the interrupts that the pgones os assigns to your music xontrol devices. Which ever music control, assigned the higher interrupt level wins the race.
Best Answer01-12-2016 00:57
01-12-2016 00:57
o..kay? but this doesn't explain why other bluetooth headphone devices work seemlessly. IF anything, I must have stumbled upon a bug that fitbit should fix.
Best Answer01-18-2016 18:56
01-18-2016 18:56
How can I report this issue to fitbit people so that it can potentially get fixed in a firmware update?
Best Answer01-27-2016 01:54
01-27-2016 01:54
I have the exact same problem! Its with a Blueant Pump bluetooth headphones and LG G4 phone. Individually they connect fine, but once it comes together the Fitbit cant seem to do music control anymore. But it still syncs with the app fine.
It gets really frustrating especially during the run 😞
Best Answer03-08-2016 22:12
03-08-2016 22:12
Best Answer03-10-2016 01:24
03-10-2016 01:24
Best Answer03-10-2016 13:32
03-10-2016 13:32
Fitbit simply needs a firmware update to fix this! I believe that is all it takes.
05-02-2016 11:22
05-02-2016 11:22
Hello there guys! Thank you for providing your ideas and suggestions. I want to encourage you to voice your opinion in our Feature Request board. Feel free to share your idea with us, in that way you'll get a lot of votes!
Good luck!
