If you use the activity tracking feature then the Surge uses GPS to measure your distance. If you are not actively tracking then it will use your stride length to measure your distance.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
You are right. Sorry. From my use of the Surge GPS I don't find a feedback loop to adjust stride lenght from a GPS tracked walk or run. I belive that if you want to do this you will have to do it manually. You can request this in the Features Request forum.
