04-26-2016 11:30
04-26-2016 11:30
I have noticed that in the past few weeks the floor count is wildly high. For example, on my morning walk today the elevation change is about 70 ft. The Surge hows that I have climbed 165 floors. The dashboard shows I climbed 14,000 floors in the past few weeks! Any one know how to correct this problem or has my Surge really screwed up permamently?
Best Answer04-26-2016 11:40
04-26-2016 11:40
It will add floors when it is windy or cold.
If you enter "driving" as an activity during the times it happened, it will remove it for you.
https://help.fitbit.com/articles/en_US/Help_article/Can-I-delete-data
Wendy | CA | Moto G6 Android
Best Answer04-26-2016 11:41
04-26-2016 11:41
Also a restart might help it from happening again
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Best Answer06-23-2016 09:38
06-23-2016 09:38
Best Answer08-02-2016 06:44
08-02-2016 06:44
Thank you for the recommendations @WendyB that could help in most cases.
The fact that the wristband is coming off could be a factor. You could also clean the tracker's altimeter (the small device that measures the altitude). That could be obstructed with microscopic dirt that prevents an accurate tracking. You can use hand sanitizer and a tissue or moist a cotton swab with isopropyl alcohol and carefully clean the small hole on one side of the tracker, opposite side to the butto. Do not use detergent, abrasives or submerge your tracker in water. Dry it completely and check how it goes after tomorrow. In case it won't improve the tracking don't improve, contact support to check your warranty for a replacement under warranty as the bracelet is damaged.
By the way, welcome to the Fitbit Community @alabamatom happy stepping! ![]()
Parliamo di calcio Qual è la tua squadra di calcio preferita?
