Help all surge users!!
My surge reser to midnight at 10am today - losing all stats for the day so far. My surge is now reading the wrong time and will not sync correctly with my dashboard. My dashboard currebtly remembers the activity from the day before the re-set and the day after the re-set.
Is there a way to change the clock on my surge or to re-set my surge completely?
Thanks,
Heather
Best AnswerYou can set your clock to auto (which will then follow the device you sync with) or do it manually. Both are in the settings section. Good luck!
Scott | Aviano Italy
Force, One, Charge, Charge HR, Surge - iOS
