07-23-2018 23:53
07-23-2018 23:53
Hey guys i know it's been posted alot but I've tried searching and cant find the right answer. This is my replacement watch i got last feb. It's now doinf exactly what my first one did. IveI contacted fitbit they wont replace it but offered discount on a new one... 😞 I appreciate the offof but I dont have alot of ccas to throw around. Anyways has anyone tried any type of glue to hold it in place. Ive tried a 24hr super glue and it last all of a hour 😞
I dont wanna buy a new watch when this work perfectly. Its just the band. But furstated there is a easy way to just replace the band 😞 and it to stay in place
Thanks in advance
07-24-2018 07:06
07-24-2018 07:06
Hi @Chrissiecxc
I did a search of the Surge forum area and found a member who was able to replace their out of warranty band. They gave a link to this blog entry that has images and takes a person step by step in replacing the band. Give it a look - click - it might be something you feel able to do
Let us know what happens.
07-24-2018
12:59
14:00
YojanaFitbit
07-24-2018
12:59
14:00
YojanaFitbit
Hey thBkst. I had boufhg .rellac repla band for my first watch but they replacement wasnt big enough to slip the watch in ;( was gutted wasted money on aomething that didnt work. Wish there was fitbit shop in town to fix it lol
My band has now falleb off .With no option but to glue it once I find the right glue
08-04-2018 05:18
08-04-2018 05:18
HI Chrissie
you can get a new strap at Amazon https://www.amazon.co.uk/dp/B07415ZKDT/ref=asc_df_B07415ZKDT54518825/?tag=googshopuk-21&creative=221...
only costs £10 approx Just changed mine as it had torn away around the fixings.
08-04-2018
09:05
14:00
YojanaFitbit
08-04-2018
09:05
14:00
YojanaFitbit
Thanks vut i bought one of those last tome for my first surge and it was connecting on. 😞 Inside the strap was too small to fit. May try again once finances level out so ibI ha soasp cash
So i will have spare cash. My lovely phone wouldn't correct my words there lol
08-06-2018 00:15
08-06-2018 00:15
I buy replacement straps from wish. Also put a sleeve on it as it will last longer can be bought on ebay. Only problem is shipping takes a long time.
08-06-2018 00:19
08-06-2018 00:19
08-06-2018 00:27
08-06-2018 00:27
Yeah it is annoying especially when you see other watches so much cheaper.
08-06-2018 09:11
08-06-2018 09:11
Go to amazon and you can buy a replacement band very cheaply. Fitbit will not sell you one.
08-06-2018 09:40
08-06-2018 09:40
08-10-2018 11:30
08-10-2018 11:30
Hi @Chrissiecxc it's really nice to see you on the Forums. Thanks for all the help @horsedoc, @Kevharvey, @JohnJamesH and @Odyssey13.
I can see that you really like you Fitbit since you're putting a lot of effort in repairing it. This specific model doesn't have the option to use exchangeable bands, so it's hard to make sure that other band will fit the tracker. Fitbit has released other options with the time, we have trackers and watches with exchangeable bands. You can find more about this here.
In case that you want to review your warranty options, you can let me know so I can request a case for you.
I'll be waiting for your reply!
08-10-2018 11:57
08-10-2018 11:57
08-14-2018 09:21
08-14-2018 09:21
Thanks for your quick response @Chrissiecxc. You can click on the link again and at the bottom of the page you will have the option to change the country to see the information available for the place that you live in. Sorry that I didn't mention it before, my bad.
Thanks for your feedback, I hope you can find the right fit for you. Let me know if I can help you out with anything else.
