12-25-2016 14:55
12-25-2016 14:55
I got a surge today attempted to charge it but the charger kept slipping out as soon as I let go of it any ideas??
12-25-2016 20:47
12-25-2016 20:47
It does fit in a certain way. If its not fitting turn it around please
Wendy | CA | Moto G6 Android
12-26-2016 07:04
12-26-2016 07:04
It's great to see that you've visited the Fitbit Community, welcome @Steevee83! ![]()
Adding to the information that @WendyB gave you. If you check this picture you will notice that the charger has an specific shape that fits with the entry on the back of your Surge. If you're able to plug it in but it is too loose, it's best to contact Customer Support so they can assist you with that! ![]()
Good luck with your new Surge and enjoy your workouts, I hope to see you here more often! ![]()
I'll be around in case you need more help! ![]()
