Surge display stuck with fitbit logo sign.
Today morning when I took my fitbit surge for my usual run, it was working fine. When I finished my run and came home and as I chose to sync it with my PC using the USB cable, it failed syncing with my PC. So, I shutdown the fitbit and want to restart it, thinking it may work. But when I restarted it got stuck in the initial stage of "Arrow sign" or we can call it a fitbit "logo sign", and it stays in that sign for ever and doesn't move to the next stage of showing the time or settings. Then I even tried to reset it by pressing the home and select button together and the screen went blank. After few minutes I switched on and it again gets stuck on the same fitbit logo screen. I tried to do this for almost 5 times. Still it is stuck with the logo sign and not moving forward. This morning as usual I ran for 8.1 kms and I wish I could use that data as well; hoping to set it right for my tomorrow's run without loosing today's data. Please do the needful. Thank you. Regards, Venkatesh S KToday morning when I took my fitbit surge for my usual run, it was working fine. When I came home and as I chose to sync it with my PC using the USB cable, it failed syncing with my PC. So, I shutdown the fitbit and want to restart it, thinking it may work. But when I restarted it got stuck in the initial stage of "Arrow sign" or we can call it a fitbit "logo sign", and it stays in that sign for ever and doesn't move to the next stage of showing the time or settings. Then I even tried to reset it by pressing the home and select button together and the screen went blank. After few minutes I switched on and it again gets stuck on the same fitbit logo screen. I tried to do this for almost 5 times. Still it is stuck with the logo sign and not moving forward. This morning as usual I ran for 8.1 kms and I wish I could use that data as well; hoping to set it right for my tomorrow's run without loosing today's data. Can anyone suggest a way to retrieve the data and also make it work properly.  Thank you.
3 REPLIES 3
Sounds like you have done everything you can. I would contact support and see what they can do for you
Use the help Link at the top of the forum
Community Council Member
Wendy | CA | Moto G6 Android
Hey teshlee, I have the same issue with a Surge. Wiiliger turned me on to JoesGE. They said they could fix it, so I’m sending it in and crossing my fingers.
Teshlee.
Just got my Surge back from JoesGE. It works like new. They replaced the main board. $50 total; they pay for shipping both ways.
