08-20-2016 05:56
08-20-2016 05:56
Hi, I'm thinking about getting a Surge but it says the strap sizes start at 14cm (5.5") and my wrist is only 11.5cm (4.5"). Will it fit me? And even if the strap fits, will the watch face be huge? Thanks
Best Answer08-20-2016 07:57
08-20-2016 07:57
Hi @jcdizzystar
Feel free to check out the Surge Size page, it displays how large the bands are, the tracker itself.. and possible to download / print a sizing guide to see which band suits the most..
https://www.fitbit.com/uk/shop/surge
Consider getting a Blaze instead, as it's less bulky than the Surge (as it doesn't has gps build in though able to use the gps from the phone if desired), has a coloured screen, exchangeable bands (leather and metallic band(s)) available..
Has also the more secure wristband like the Charge HR & Surge.
In case the band breaks on the Surge if out of warranty needing to buy a new tracker..
The Blaze is a bit cheaper than the Surge.
