01-03-2016 00:19 - edited 01-03-2016 00:23
So I have had my Surge for about a month now, and the screen is all foggy, and the touch screen has stopped working.
It hasn't been exposed to more moisture than the 5ATM test pressure should be able to handle, I'm thinking it's just full of sweat!
Does anyone else have this problem?
Best Answer01-03-2016 00:41
01-03-2016 00:41
It certainly shouldn't be doing that!
You should still be within warranty but you can check at www.fitbit.com/returns
If you are then you can contact customer support via this link: http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
