05-07-2018 10:32
05-07-2018 10:32
My surge tracker and steps after syncing via the app are different. The app calculates it as less
Best Answer05-08-2018 07:07
05-08-2018 07:07
Are you sure that a sync really happened @HannahDavies how long ago does the app say the last sync was .
The app normally does not calculate the steps but displays what the tracker counted .
If a manually added run/walk was added, or the app was used to record a walk/run then yes gf's app would calculate the steps. However after the next sync the step count on the ionic and app will be synced up and match .
Best Answer05-08-2018 07:56
05-08-2018 07:56
Best Answer05-08-2018 08:02
05-08-2018 08:02
I'm still not sure wichwhof the 4 possible devices the Fitbit app is running on.
Have you killed and restarted the app?
Logged out and back in?
