01-22-2016 01:25
01-22-2016 01:25
Hi there!
I have recently purchased my Fitbit Surge. It arrived yesterday (21/1/2016).
I updated and charged the fitbit to full during the day whilst I was at work so I know that it is not the battery running low, but occasionally the screen will slowly fade out untill it is completely blank! I will then have to press buttons on the watch to turn the devise back on.
This is very frustrating for me considering it is a new purchase. I'm concerned it will turn off during exercise and won't log properly.
I have been looking at the forum and I can't seem to find anyone else with the same issue as this. I'm thinking that I probably have a faulty devise.
Any ideas?!
Thanks,
Toby.
01-22-2016 05:23
01-22-2016 05:23
Hi @Toby4888
Did you turned on the tracker normally or restarted the tracker?
If not already done, it's possible to restart the tracker.
Restart the tracker
URL: Click to go to the Fitbit Help Article 'How do I restart the tracker?'
When the issue remains, the tracker needs to be exchanged.
Best Answer01-22-2016 05:42
01-22-2016 05:42
Hi @SunsetRunner
Thanks for your response. I have already restarted the tracker multiple times with no luck. After a little more research I have actually found a discussion for someone that is experiencing the same issue:
https://community.fitbit.com/t5/Surge/Surge-screen-fading-and-blank/m-p/945534
I purchased through Amazon.co.uk and they have agreed to give me a full refund. I am going to put the money aside for the Blaze as and when it becomes available.
Cheers,
Toby.
01-22-2016 07:19
01-22-2016 07:19
Your welcome @Toby4888
The Fitbit Store mentions when pre-ordering the Blaze, it ships in March.
Wishing a awesome day / weekend
