01-15-2016 07:16
01-15-2016 07:16
Hi,
Had my surge since May 2015. Really like it, but since the last FW update have noticed that my surge loses about one minute per day and the battery is only lasting about 4 days rather than the week it used to have.
I do not use the backlight, nor do I have it paired with my phone for texts, etc. HR is set to auto. Only one alarm. Notifications is off.
Version is 16.34.5.14 and I synch to a Windows 10 laptop.
Any ideas?
Blaise CD
01-17-2016 16:30
01-17-2016 16:30
@bcdechert Welcome to the Fitbit family! Hey, that sounds fairly odd. Just out of curiosity, have you tried restarting your Surge? Thanks for indicate that your notifications are off, 'cause this is one of the reasons why your Surge's battery is draining quickly. Also, your HR monitor should be set to Auto just like you indicated. This will definitely ensure a longer battery life. However, if you're using the GPS a lot that might be the reason why the battery is only lasting 4 days. Give that restart a try and keep me posted with the results. Oh! just make sure you're charging your Surge for appropriately 1 - 2 hours. Keep me posted!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
01-18-2016 09:45
01-18-2016 09:45
01-18-2016 14:31
01-18-2016 14:31
@bcdechert Thanks for getting back to me! Hey, seems like you've exhausted all troubleshooting steps for this issue. I recommend contacting our Support Team for a second opinion. Good luck and keep me posted with the outcome.
