11-03-2017
00:56
09:25
YojanaFitbit
11-03-2017
00:56
09:25
YojanaFitbit
Recently my Surge started needing to be turned off, then on, each time I want to sync it to my iPhone. All-day Sync is activated, and the Surge and the iPhone are both updated. Has anyone else experienced this, and, has anyone discovered a fix?
Thanks a lot,
Greg
11-04-2017 03:25
11-04-2017 03:25
I've found on my Android phone that force stopping the app then opening it up again always gives me a successful sync when I'm having issues.
I have all day sync and always connected turned off.
11-04-2017 09:29
11-04-2017 09:29
How you doing @GregAhl? Thanks for joining this family, hope you like what find here!
Thanks for the suggestion @Crazy-Fritter! @GregAhl thanks for trying those steps. You can also the next steps to make sure your Surge will connect properly:
This should solve any syncing issue that you're having, please keep me posted on the resolution!
