02-01-2019 14:53
02-01-2019 14:53
I have been using my Fitbit Surge for a while now and have had no issues. Over the last week it has increasingly become more difficult to swipe and now it doesn’t swipe at all. I have tried rebooting, resyncing, reconnecting but to no success. Any further ideas?
06-08-2019 20:51
06-08-2019 20:51
I also have the same failure of Surge touch screen, The Fitbit support team told me it's a hardware failure and suggest me to buy a new one. I have told the support team my Surge only last for less than 2.5 years and throw it away just because the failure of swipe screen (other functions are all nomal).
I have suggested the support team to enhance the Surge operations, to fully utilize the right upper button which now is seldom used to have the functions the same with swipe screen.
That is
Home button -> RUN mode -> right upper button -> Hike mode .....
RUN mode -> right lower button -> FREE RUN -> right upper button -> LAP RUN...
I strongly suggest the Fitbit company to adopt my suggestion to rescue the easy failure of swipe screen.
06-08-2019 20:57
06-08-2019 20:57
No solution works...you need to buy a new watch...also I recommend you, not to buy a fitbit ever again
06-08-2019 21:14
06-08-2019 21:14
06-13-2019 16:49 - last edited on 08-26-2021 06:11 by JuanJoFitbit
Actually, I was looking for another issue regarding my Surge but stumbled onto this one. Thought I would give you my experience. Was having the same issue with mine when I received a no cost replacement (with no warranty). Ever since the new one has been issue free. As far as swiping is concerned; try storing it for 24 hours in an airtight or screw top jar. It's possible there is a humidity problem. Otherwise, try complaining. If the device is relatively young you may be lucky enough to qualify for a free replacement. I just love the GPS feature. Good luck.
BTW..my issue was which formula should be used to convert road cycling exercise to steps. Currently I get zero steps, which totally unacceptable.
Oops!!! forgot to mention, you need to half-fill the jar with rice (too absorb any moisture in your device)
Sorry about that......good luck.
Moderator edit: merged reply
06-13-2019 18:53
06-13-2019 18:53
06-13-2019 19:08 - last edited on 06-18-2019 15:55 by EdsonFitbit
Hey, thx for the tip, it’s worth a try!
06-18-2019 14:21
06-18-2019 14:21
I can no longer swipe my surge anymore. after dealing with the bubbling band and now this i am regretting this fit bit
06-18-2019 14:43 - last edited on 06-18-2019 15:56 by EdsonFitbit
I had to buy a new band also
06-22-2019 06:28
06-22-2019 06:28
i too have have a problem with my surge, touch screen not working i tried pressing 3 buttons together and restarted aftere 10 seconds, i did not work pls do help me
06-22-2019 16:54
06-22-2019 16:54
