06-12-2018
14:07
05:33
YojanaFitbit
06-12-2018
14:07
05:33
YojanaFitbit
My surge stopped connecting my exercise for the day to Fitbit.I logged out of both apps I removed the surge and added back on .I shut my phone off.
nothing helping 😩
Moderator edit: Updated subject for clarity.
06-13-2018 05:31 - edited 06-13-2018 05:32
A warm welcome to the Community @Jamie27. Thanks for the steps that you already try, sorry that it didn't solve this issue.
I'd recommend re-linking the two accounts by doing the following:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
I hope this helps, let me know the outcome.
