02-01-2016 08:56 - edited 02-01-2016 09:43
All of a sudden (approx two weeks ago) my Surge stopped to "hold" charge. Battery drains so fast I have to charge every second day.
Until than one battery charge would typically last 4-5 days - charge during weekend and repeat thursday/ friday depending of GPS use.
Typically I leave it to charge for a few hours (1-3hours) until the lightning bolt AND my dashboard states it's fully charged.
I am using it 24/7 as a activity and sleep tracker exept every second day I track a Free run approx 45 min duration.
I charged it yesterday till it was fully charged. Took it on a 'free run' this morning for approx 45 min. Now after 24 hours it is back to medium charge.
I am aware that it usually will last for an extra day after you receive the empty battery email, but I don't want to rely on that so I typically charge when the email arrives.
Have reset it several times for no avail.
This bavavior started all of a sudden as I said. I don't think we have got any FW or app updates for the last 2-3 weeks either
Any one else experiencing their Surge (or Fitbit) not holding charge?
01-25-2019 09:47
01-25-2019 09:47
I apologize for the delayed response and thank you for visiting the forums @Lavena123 and @Pescho33.
I really appreciate that you have shared your experience with us and that your devices are working properly.
Keep on visiting the forums.
01-27-2019 18:18
01-27-2019 18:18
My surge is basically being used as a watch & heart monitor as i have some heart issues only & will only hold a charge now for about 24 hours. Its about 2 years old but there appears to be no fix & so its basically garbage now . . I guess I wont be buying another fitbit as thats too short for a 300 watch to last so its back to a regular watch for me.
01-27-2019 18:24
01-27-2019 18:24
01-29-2019 05:34
01-29-2019 05:34
Hi @SunsetRunner, thanks for posting your comment on the Forums. Welcome!
Sorry you feel that way about your tracker. Have you check your options with our support team. Fitbit Surge was very popular but we no longer have that model as an option. We appreciate your feedback as our team is always improving our servicies and products. Let me know if I can request a case for you.
@Lavena123 Thanks for sharing your experience.
I'll be around.
01-29-2019 06:12
01-29-2019 06:12
01-30-2019
06:32
11:35
AndreaFitbit
01-30-2019
06:32
11:35
AndreaFitbit
For the purchase price and the number of issues 25% was a joke. I switched to Garmin and am thrilled.
Moderator edit: format.
01-31-2019 09:25
01-31-2019 09:25
Thanks for getting back to us @FrankTMarie and @KarenPhD. I apologize for the delayed response and thank you for your comments.
We don't want to create frustration in our customers. Fitbit has been designed to provide motivation and help you to reach your daily goals to success. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on what you share here.
Thanks for the feedback,
01-31-2019 11:33
01-31-2019 11:33
02-02-2019
12:20
10:54
YojanaFitbit
02-02-2019
12:20
10:54
YojanaFitbit
Yeah were gunna need you in the charge 3 section incase you missed me tagging you for 3-4 days.
Moderator edit: Format.
02-05-2019 10:56
02-05-2019 10:56
Hi @FrankTMarie and @Chancelor, thanks for sharing your feedback. We're always glad to see you on the Forums sharing your Fitbit experience. Your voices are being heard. We're actively reviewing your responses and providing feedback to our product development team.
See you around.
Best Answer05-27-2019 16:59
05-27-2019 16:59
Exactly what is happening with my Surge. I have been using it everyday for a year, and all of a sudden it won’t hold a charge. I cleaned the contacts, reset it, seemed to work ok for about 2 weeks, now it is happening again. Any suggestions
Best Answer10-11-2019 07:07
10-11-2019 07:07
My Surge not holding charge. What can I do about it?
Can it be replaced?
Best Answer10-11-2019 07:22
10-11-2019 07:22
When I called Fitbit, I was told that since it was out of warranty that they could only offer me a 25% on another device.
Best Answer10-11-2019 14:18
10-11-2019 14:18
10-12-2019 04:03
10-12-2019 04:03
Best Answer10-16-2019 06:49
10-16-2019 06:49
I have replaced the battery in my Surge two times with an Ebay $15 battery. The best of the two has to be charged twice a day. I'm sure the case won't hold up to try a third. The best results I've had is to unplug and replug the charging cable when it says it's fully charged. Make sure the little battery icon is fully filled to the very end. I agree this model is a throw away unit. I liked my two previous Ultra's much better. I hate to leave Fitbit after eight years and loose all my data but mostly likely will go.
Best Answer10-16-2019 14:59
10-16-2019 14:59
Best Answer10-16-2019 16:58
10-16-2019 16:58
Best Answer10-16-2019 17:38
10-16-2019 17:38
Best Answer03-06-2020 01:30
03-06-2020 01:30
Hi I'm also having a same issue I charge my surge at night then by morning theres no battery life left. I'm unable to use function on the watch except the time, steps etc also I cannot rest my watch and menus.
I'm going to let my watch run out life and then reset the app on my phone see if that helps but my gut feeling says it won't make a difference.
Could it be a software issue?
Steve
