04-19-2017
08:44
08:18
YojanaFitbit
04-19-2017
08:44
08:18
YojanaFitbit
Recently my Surge does not allow me to swipe past Run as a selected activity, where as before I could select workout or other activity. I have reset shortcuts and synced both on App and through FitBit.com direct, nothing works.
The workout will record automatically but I can't select on Surge itself.
Does anyone have any ideas to help?
Thank you
Moderator edit: Clarified subject.
04-19-2017 12:39
04-19-2017 12:39
I've noticed you are new around @DanD01, so let me give you a warm welcome to our Community.
Thanks for the details. You can try to restart you Surge a couple of times and then try to force sync it. It should do the trick.
Let me know how it works!
04-20-2017 06:14
04-20-2017 06:14
Hi .. thank you for the welcome and the advice ... it worked! (first time) so I'm back up and running or whatever other chosen type of activity I wish to select! Thank you
05-01-2017 08:16
05-01-2017 08:16
Hi @DanD01! Hope you're doing well, and enjoying some healthy activities!
I'm glad to know that you're back on track! I invite you to mark this post as the solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions
Please also take a moment to visit our Discussions board where you will find other members sharing their experiences and tips. This is a really good way to stay motivated towards your goals. In case that you haven't do so, check it out! You might be interested in these topics: Saturday Humor or What is the most interesting place that you have walked run?
Happy stepping!
