02-04-2016 12:27
02-04-2016 12:27
I have been having a probelm with my Fitbit Surge. My Surge syncs fine with my phone, but not with my computer. When I press "sync now" on my computer, it says it can't find the device. (even though it is right next to my computer) This is annoying because sometimes I don't have my phone but I want to sync my watch. Does anyone else have this problem? Thanks for the help!
Best Answer02-04-2016 13:15
02-04-2016 13:15
The Surge is only capable of talking to one Bluetooth device at a time so you'd need to make sure Bluetooth is off on the phone (or it's too far away to be an issue). Additionally, if your phone is bonded to your tracker for notification purposes, I think that needs to be disabled too.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
02-04-2016 15:26
02-04-2016 15:26
Hi Mike, I tried turning off the notifications on the Surge and turning off the bluetooth on my phone, but my computer is still unable to detect and sync with the Surge.
Best Answer04-05-2016 16:31
04-05-2016 16:31
Hello @Sean_S! I'd like to know if you're still having syncing with you Surge. I recommend a quick restart, this will help you to refresh all your information on your Surge. It would be a good idea making sure that you're logging on the correct email (a typo?). Besides that you may want to try using different USB ports. If all the previous steps don't work proceed to set up your tracker as a new device by doing the following:
Keep me posted!
