06-20-2017
07:08
08:00
YojanaFitbit
06-20-2017
07:08
08:00
YojanaFitbit
My phone. Samsung S7 cannot communicate with my tracker since Sunday. Any ideas? Tried all the troubleshooting tips. Thanks
06-23-2017 08:00
06-23-2017 08:00
How you doing @RobWhitept? Thanks for joining this family, hope you like what find here! ![]()
Excellent tip @SteveH! You might get some good points to make your Surge to connect property with your phone in this master post. In case that you need extra help, feel free to post back. ![]()
If you were able to fix the issue with @SteveH suggestion I invite you to mark his post as the solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions
Please keep me posted! ![]()
Best Answer06-20-2017 07:16
06-20-2017 07:16
Was one of the things you tried a restart of the fitbit using this procedure?
https://help.fitbit.com/articles/en_US/Help_article/1186/
If so, how many times did you try it? It's known to not always work and it's recommended to try it at least three times.
06-23-2017 08:00
06-23-2017 08:00
