I'm happy to see you here @Bobher13, please receive a warm welcome!
Thanks for reaching out the Forums to get some help for your Surge. You can try to log out/in from the App or restart "Bluetooth". Once you've done that to Force sync your tracker Tap on "Account" in the Fitbit App, then tap on your "Surge" picture and find the option "Sync now" to force sync.
Our good friend @SunsetRunner, has a good point there; so please check some requirements that your phone and Surge should have in order to successfully communicate:
Requirements:
Also check your phone Permissions and leave location on to keep syncing and getting notifications with your phone, for more info check this suggestions from @ErickFitbit. ![]()
If the syncing issue remains with a mobile device I would recommend following the steps below:
Hope this helps and welcome again! ![]()
