01-12-2019 11:18
01-12-2019 11:18
I have an issue that started on 01-10-2019 at approximately 10:00 am. My Surge will only show the date of 01-10-2019 and a time within the 10 o'clock hour. Also, it constantly switches between the home page and the exercise page then restarts. I have tried syncing, resetting, you name it, and nothing works. It has worked well until now. It started when I restarted the watch (something I have to do often so it will synch). It has the most recent firmware, and my app is up to date. Something is going on with the tracker.
01-13-2019 07:30
01-13-2019 07:30
Welcome to the Forums @mmckeehan, thanks for trying all those steps.
I'd like to check with you some options that your Surge should have on the settings. Please check the steps in this master post.
Let me know if you have questions.
01-13-2019
09:44
06:58
YojanaFitbit
01-13-2019
09:44
06:58
YojanaFitbit
None of that changes anything. It's like the tracker is stuck in a software loop. It always returns to the same date and time when reset. Then it begins a routine of date/time page, to Run or excercise page, turns itself off and on, then does it all over again until the battery dies. Charge it back up, and it just does the same thing. It's clearly sofware or hardware with the tracker.
Problem is not solved. This is showing solved by accident
01-15-2019 07:44
01-15-2019 07:44
Thanks for getting back @mmckeehan and trying those steps. I updated the thread removing the accepted solution.
Please try resetting your Surge:
If your tracker still doesn't work after a restart, let me know so I can request a case for you.
