07-17-2019 15:26
07-17-2019 15:26
My Surge will receive call notifications but not text messages from my Sony Experia ZX. I have tried all the trouble shooting... Unpairing, checking Bluetooth etc. The permissions are all on including for sms. Any help?
07-29-2019 16:46
07-29-2019 16:46
Hi there
What was the solution to this? I have been having the same issue with a Huawei phone.
Thanks
Mark.
07-30-2019 13:26
07-30-2019 13:26
Hi i also have had this problem mine is with Moto g6. I have also done all of the help things as well with no luck.
Best Answer08-02-2019 07:15
08-02-2019 07:15
I have the same problem using my Samsung J3. Started out displaying messages just fine but after recent update all it shows is "New Message" or nothing at all. Have done all of the troubleshooting. Worked with a tech at FB too. Nothing seems to work.
10-26-2019 13:33
10-26-2019 13:33
Hi Ksmith7042,
Unfortunately i have had no luck since the latest update. Mine still doesn't sync properly and i have to fully recharge it and uninstall app and re install app and reconnect every 2 to 3 days it is annoying
Best Answer11-27-2019 10:27
11-27-2019 10:27
Same thing for my iphoneX.
It vibrates and notifies for calls but nothing at all for texts...
