05-03-2016 11:08
05-03-2016 11:08
I spent 45 minutes cutting my grass this morning and my Surge recorded the activity as riding my bike. How did this happen and how can I correct it?
Best Answer05-03-2016 12:04
05-03-2016 12:04
If it came from Smart track then use the Pencil next to the record and search for what you need to change it
Wendy | CA | Moto G6 Android
05-03-2016 12:04
Best Answer05-25-2016 13:34
05-25-2016 13:34
Tried to get this thing to do a somewhat accurate step count but can't even get it close. Did a step count of 50 steps. It never moved one step. A minute later I checked it, and it jumped over 1,300 steps. Tried doing the non-dominate hand. The other day it said I did my first 10,000 step day and there is absolutely no way I did 10,000 steps. The only thing that seems to be accurate is the watch and heart rate monitor. I have compared it to an elliptical trainer and it is within 5 beats per minute consistently. Mowed the grass the other day and it takes about 30 minutes. Said I burned almost 5,000 calories. I work out on an elliptical trainer pretty hard and only burn around 500 or so calories. Total disappointment for $250 knowing that as soon as the band breaks the watch is worthless. Never again....l
07-14-2016 09:45
07-14-2016 09:45
What it did on mine was to record hours and hours of "outdoor bike" when I didn't do any activities AT ALL. How could that happen?
Best Answer08-12-2016 06:49
08-12-2016 06:49
It's nice to see you around the Community @RetiredFE @ilse49, hope you're doing great! I agree with @WendyB, this seems to be SmartTrack that is recognizing those activities.
As you may know, the SmartTrack feature available on Fitbit Alta, Fitbit Blaze, Fitbit Surge, and Fitbit Charge HR automatically recognizes and records select exercises to ensure you get credit for your most active moments of the day.
By default, SmartTrack recognizes an exercise that lasts at least 15 minutes. You can lower this setting to 10 minutes, or increase it as high as 90 minutes. For example if you only want SmartTrack to detect your longer walks, you might change your duration settings to a 30-minute minimum.
You can stop your tracker from trying to auto-recognize one or more exercise types. You may want to do this if SmartTrack sometimes mistakes your movements. For example, if Elliptical workouts appear in your exercise history and you don't use an elliptical machine, turn off auto-recognition (SmartTrack) for Elliptical.
Fitbit.com Dashboard
Fitbit App for iOS
Fitbit App for Android
Fitbit App for Windows
On the other side, see what my friend @Julia_G found out by reading her post.
Happy stepping!
