05-23-2019 03:39
05-23-2019 03:39
Since about a week ago swipe on my Surge screen will not work unless it is connected to the PC for sync/charge. Was there a flawed product update that caused this ?
Since I mostly use the step counter and the heart rate, is it possible to get on the screen the time, the step counter and the heart rate at the same time ? In this case I would not bother with the swipe issue.
Thanks in advance.
Best Answer05-23-2019 03:52
05-23-2019 03:52
Hi @Discoazul. It’s been quite a while since I’ve used the Surge. It may be best for you to contact Support. They should be able to advise you.
Best Answer05-24-2019 08:16
05-24-2019 08:16
my surge also stopped swiping,even when connected for charging.
I am thinking it is a software glitch, is there going to be any help from fitbit or are we sol?
It worked great until a few days ago.
