02-23-2016 19:10
02-23-2016 19:10
02-24-2016 06:55
02-24-2016 06:55
@Aldog1977 Welcome to the Fitbit Community! Have you also tried to turn off the heart rate feature, sync, then turn it back "on" or "auto", and sync again? You can do this from the tracker itself, you will find the option under the settings.
Let me know if you have already done this. Keep me posted.
02-24-2016 12:13
02-24-2016 12:13
02-26-2016 01:54
02-26-2016 01:54
04-12-2016 10:18
04-12-2016 10:18
Hello there @Aldog1977! I appreciate the time you took to work on this. At this point, I highly recommend contacting Support, I'm pretty sure they'll give you the hand you need on this. Thanks so much for your help @Catbossness and @SantiR!
Good luck!
