05-28-2018 12:59
05-28-2018 12:59
My Surge strap has all of a sudden split on the top by the watch face. I have only had the watch 3 months! Can you please tell me what I need to do
Many thanks
06-12-2018 06:39
06-12-2018 06:39
Welcome to the Forums @Dory950, glad to see that @WendyB and @marty0050's respond helped you! I'm sure out team will give you a hand with that.
@lilchris26 Thank for sharing this information and for reporting the issues with your replacement. I've got in touch with our team and they will be contacting you shortly.
Thanks for your understanding.
Best Answer05-28-2018 13:30
05-28-2018 13:30
Please contact support. Attach a picture
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Wendy | CA | Moto G6 Android
05-28-2018 14:05
05-28-2018 14:05
05-28-2018 16:24
05-28-2018 16:24
My surge is the same the strap has split. My first surge which was a gift christmas 2016 went faulty it would not connect with my mobile and the strap split. The replacement has been working fine but the strap on that has split now andd its worse than the first one. Can you glue the strap or something. No wonder they have stopped making the surge, it seems a common problem.
05-29-2018 06:09
05-29-2018 06:09
Ebay has plenty of "aftermarket" straps. It is easy to replace. Purchase with the screw driver, the screws are small. The last time I checked FitBit only offers entire units, not the strap.
05-29-2018 09:31
05-29-2018 09:31
thank you I will check this out
06-12-2018 06:39
06-12-2018 06:39
