10-08-2017 10:05
10-08-2017 10:05
I was jogging in a 6,5 km loop. after 1,5 km it suddenly stopp to register HR. This i have used for 18 months and it has been all good the whole way. Until now. After it will not start to register HR. The green lights is at function.
Best Answer10-19-2017 16:26
10-19-2017 16:26
A warm welcome to the Community @Fleming! Thanks for the details. I would like you to make sure that you're following these tips to properly wear your Surge and detects heart rate data, What should I know about my heart rate data?
Also, you can try restarting your tracker and keep monitoring it.
Hope this helps!
10-19-2017 16:26
Hope this helps!
